2020-06-14 8:27 AM
2020-06-16 6:59 AM
The L149 was a linear power driver with +-20V supply voltage and 4A driving capability, obsoleted long ago.
There is no replacement available from STMicroelectronics.
/Peter
2020-06-16 7:15 AM
thank you so much, but I have a problem, I have board that uses this kind of IC and its critical to replace it with something, my output driving is only 2A, I tried to replace TDA2030A and TDA2003 but non of them work, what is your suggestion?
I would appreciate if you can help me./.
2020-06-16 8:21 AM
Sorry, STMicroelectronics is not able to suggest any alternative.
But some hint: audio amplifiers are not optimized for DC operation, so it might be worth looking for a power op amp providing at least the parameters mentioned above or the current you are mentioning.
Good luck in finding the right part, I'm sure you will.
/Peter
2020-06-16 10:58 PM
thank you so much your suggestion helped me. I need it very much thanks./.
