Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
AM looking for datasheet of ST Chip
Hi all, Can somebody support in getting datasheet of "324 ST MZCS903" which is a 14 - pin chip.Am unable to get from internet .Thanks in advance.Rohitrohit.kadecha@battrixx.com
RKade.1 by Associate III
  • 1093 Views
  • 1 replies
Low power voltage reference with NPN transistor
Hi,I'm looking for advise concerning a low power voltage reference using NPN transistor as following :Q2 is used as diode (with negative TC)Q3 is used as zener diode (with positive TC)This circuit create a temperature-compensated +6V reference.So my ...
BKOSI.1 by Associate II
  • 1294 Views
  • 1 replies
how to read FDA801 DB Data?
i read the data sheet about FDA801 and try to read DB data , the data i read were all 0x00 ,But none of the speakers came through , i think there is something wrong in my process procedure . Here's how I tried it:May I ask if this process is correct?...
Ssong.1 by Associate
  • 1071 Views
  • 1 replies
