2020-02-19 11:27 PM
Greetings Friends,
I have STM8S Discovery Board with STM8S105 micro controller. I want to use SWIM pin as general purpose IO and also want to use it to upload the code.
Is there any possibilities ?
2020-02-22 03:14 AM
Using the SWIM data pin as I/O should just work normally as expected.
It only gets more complicated when you also want to use the reset pin as I/O (common on 8-pin devices, but AFAIK not possible on the larger STM8 devices).
