2010-02-15 08:08 PM
Trigger to TIM3 from PD1 on STM8L151G6(28 pin)
2011-05-17 06:07 AM
Hi Kris,
I remember when I have needed a such config, Ihave found in the reference manual a section ''external clock source mode 1'' that explains this case of use. In your code you should probably replace ''TIM3_ETRClockMode2Config'' by ''TIM3_ETRClockMode1Config''.I hope this helps you and good luck :))).
Tell if it is OK now.
With regards,
Be happy, don't worry
