STM8S103F2 TIMER EXAMPLE(needed please)
keskintaylan
Posted on November 24, 2009 at 06:49
11 REPLIES 11
keskintaylan
Posted on May 17, 2011 at 15:05
Dear Mozra, thanks for your reply.
I tried your code.But counters still don't work.
While debugging i can see TIM2's REGISTERS. And also TIM2_CNTRH & TIM2_CNTRL.
I check these step by step, and there isn't any count.They are always ''0'' Is it normal? Is it a bug? Also i put a breakpoint in
''void TIM2_UPD_OVF_BRK_IRQHandler(void) interrupt 13''
And program never stopped.
What's wrong? :-[
I really need it. It's very important for me!
[ This message was edited by: keskintaylan on 19-11-2009 15:39 ]
mozra27
you can find below an example using Timer2:
/* TimerTick = 5 ms
Warning: fcpu must be equal to 16MHz
fck_cnt = fck_psc/presc = fcpu/512 = 31.25 kHz --> 1 tick every 32 µs
==> 5 ms / 32 µs = 156 ticks
TIM2_TimeBaseInit( TIM2_PRESCALER_512, 156);
TIM2_UpdateRequestConfig(TIM2_UPDATESOURCE_GLOBAL);
TIM2_ITConfig(TIM2_IT_UPDATE, ENABLE);
/* Enable interrupts */
enableInterrupts();
TIM2_Cmd(ENABLE);
mozra
keskintaylan
Hi everybody.
I have a problem with timers on STM8S103F2.
I'm using RIDE. I need UPD/OV interrupt urgently. I tried all of timer examples but i have nothing.Counters didin't work.(on debug screen)They are always ''0''.Interrupt was never occured!
PLEASE! give me an example of TIM2 UPD interrupt or tell some tips. Some told that i must edit STM8S.h, but how,where,what?
I will be appreciate if answered quickly...
Thank you...
[ This message was edited by: keskintaylan on 19-11-2009 12:05 ]
keskintaylan
Please & Please:
Send me a full project about TIM2 UPD&OV writing with RIDE. GPIOA.3 must toggle in interrupt routine.
Please send with using ''h'' & ''c'' files.
And please try yourself, be sure it's working.
Very very appreciate who helps.
THANK YOU!
mozra27
Can you please check the status for the PCKEN15 bit in CLK_PCKENR1 this bit should be kept set(reset value)?
you can set this bit using:
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER2, ENABLE);
mozra
keskintaylan
Dear Mozra
While debugging
CLK_PCKENR1 = 0xFF;
[ This message was edited by: keskintaylan on 19-11-2009 16:39 ]
keskintaylan
Dear Mozra,
I used STVD as you suggest.Yes timer is working.Thank you for your suggest.I guess too that RIDE have issues.
But interrupt didn't work.
Here is my codes:
void Init_TIM2(void)
/* TimerTick = 5 ms
enableInterrupts();
TIM2_Cmd(ENABLE);
void main(void)
Init_TIM2();
GPIO_Init(GPIOA, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
while(1);
keskintaylan
in ''stm8s_it.c''
#include ''stm8s_it.h''
#ifdef _COSMIC_
@far @interrupt void TIM2_UPD_OVF_BRK_IRQHandler(void)
#else /* _RAISONANCE_ */
#endif /* _COSMIC_ */
//GPIO_WriteReverse(GPIOA, GPIO_PIN_3);
GPIO_WriteHigh(GPIOA, GPIO_PIN_3);
TIM2_ClearITPendingBit(TIM2_IT_UPDATE);
/* In order to detect unexpected events during development,
it is recommended to set a breakpoint on the following instruction.
mozra27
It seems that is an issue with RIDE and is under investigation you can use STVD + Raisonance to avoid temporarily this issue
mozra
