STM8 SWIM pin as output/Debug
Options
‎2014-11-08 2:36 AM
Posted on November 08, 2014 at 11:36
1. I have STM8S003F3 & want to use its debug pin as output.
So I will configure it my code.
2. Will that make debug option dead?
On next power up, will I be able to debug the code?? Because pin will already be configured as output by that time
2 REPLIES 2
Options
‎2014-11-08 6:36 AM
Posted on November 08, 2014 at 15:36
Yes, you can use SWIM pin as output, it won't brick the device.
Options
‎2014-11-10 3:08 AM
Posted on November 10, 2014 at 12:08
Hi
I am answer this from memory, and bear in mind that I work with the STM32 but I have written the driver for the STM32 to program a STM8 with SWIM ''2. Will that make debug option dead?
'' Yes and No. If the debug is done with SWIM - it will toggle the reset line on SWIM entry. If the line is in use for SWIM - it CANNOT be used for output (ie it is held by the SWIM interface). The simple answer is : if you debug - you cannot use the Pin for output. If you do not debug - the pin will be configures for output
