[solved] STM8AF6166 TIM2 CC3 output compare (PWM out) nothing happend !
tfeuerstein
Posted on March 17, 2011 at 11:12
2 REPLIES 2
tfeuerstein
Posted on May 17, 2011 at 15:12
I found by myself !
You need to set the option byte OPT2 = 0x02 (NOPT2 = 0xFD) to enable TIM2 CC3 and disable TIM3 CC1, following is the asm file to add in your project :
;This file contains the values to program in the option bytes.
;You can change the values below according to the device datasheet.
;Be careful to respect the complement bytes,
; or the default values of the option bytes will be used.
;See the device datasheet for more information on the meaning of each bit.
cseg at 04800h
db 000h ;LOCKBYTE
db 000h ;OPT1
db 0FFh ;NOPT1
db 002h ;OPT2   //0x02 will enable TIM2 CC3 and disable TIM3 CC1
db 0FDh ;NOPT2
db 000h ;OPT3
db 0FFh ;NOPT3
db 000h ;OPT4
db 0FFh ;NOPT4
db 000h ;OPT5
db 0FFh ;NOPT5
db 000h ;OPT6
db 0FFh ;NOPT6
db 000h ;OPT7
db 0FFh ;NOPT7
end
brazov22
An easy way can be to set OPT2 which is AFR option through STVP.
brazov2
