SMT8 for OTA solution
jason239955_st
Hi Sir/Mdm,
Would like to know is there any solution for OTA (Over-the-Air) upgrade firmware for STM8?
Regard's
Jason
5 REPLIES 5
If you can erase/write the FLASH from within your own code/application, and you have enough space to hold the new firmware, you can likely create any kind of OTA or field update method you want.
jason239955_st
Do you have the solution or reference code?
jason239955_st
Hi Sir,
Does this will work for STM8S005?
Do you have an example code for the OTA firmware update?
