Decompile STM8S208 code file
sanket47
I want decompile STM8S208 code file. File format is .S19. What should be the steps I should follow?
Peter BENSCH
This is not an easy task, but you could read e.g. here and there.
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
Cristian Gyorgy
Senior III
If you can convert the S19 format to intel hex it's quite easy, try this: https://github.com/volbus/gmtdisas
