RWW
lars23
Posted on June 18, 2010 at 09:37
RWW
dhutchison1945
Posted on May 17, 2011 at 15:09
Hi Lars,I have a similar issue writing 2bytes on the e2  during the uart1 reception.
The only difference is that I write on e2 via polling mode.
b.r.
Spectre
brazov22
Hi all,
RWW feaures means cpu can continue executing a program while writing on data eeprom. So if you try to write into program eeprom the cpu freezes, while it doesn't freeze if you write into data eeprom.
brazov
