2010-06-18 12:37 AM
RWW
2011-05-17 06:09 AM
Hi Lars,I have a similar issue writing 2bytes on the e2 during the uart1 reception.
The only difference is that I write on e2 via polling mode. b.r. Spectre2011-05-17 06:09 AM
Hi all,
RWW feaures means cpu can continue executing a program while writing on data eeprom. So if you try to write into program eeprom the cpu freezes, while it doesn't freeze if you write into data eeprom.
brazov
