Issue reading program data from the flash
David  Beltran Lacasa
Good afternoon,
I would like to share an issue I’m facing with a stm8s105c4.
A feature of our main application is to calculate a CRC of the entire program in the flash. Unfortunately, when I read flash data from addresses close to the instruction in execution, the data read it isn’t always correct.
I’ve been able to reproduce the issue in this small program:
 main()
               unsigned char* p_address;
               unsigned char dataRead;
               volatile dbg;
               /* Loop and read the registers*/
               for (p_address = (unsigned char*)0x80ce; ((unsigned int)p_address) < 0x80FF; p_address++)
                              dataRead = *p_address;
                              dbg++;
               dataRead++;
In this case, when p_address points to 0x80dc, this is what we can observe in the dissasembly and the core registers:
1)      This set the address we want to read in X
0x80d7 <main+9>            0x1E04         LDW  X,(0x04,SP)
2)     This reads the value in the address point by X :
0x80d9 <main+11>           0xF6           LD   A,(X)
But the data stored in the accumulator (0x8b) is wrong according to the memory view:
Or the Srecord:
On the main application, all the data that was read incorrectly was where a LD or LDW instruction was placed. Also in this example, as 0x80dc has this disassembly:
0x80dc <main+14>           0x1E01         LDW  X,(0x01,SP)
Cosmic and ST Visual Develop was used for this example. I’ve also reproduced this in a stm8s105C6 using a Discovery board. A zip with the project is provided.
Any help will be appreciated. Kind regards,
David
S.Ma
Principal
Have you tried to make the flash reading instruction reside in RAM and called from the flash program to see if there is a difference?
S.Ma
Principal
I haven't tried, I had a bit of pressure to find a solution so I decided to forget about the algorithm we were using and switch to the _checksum16 routines provided by Cosmic.
Then I found out the same issue was happening:
https://community.st.com/s/question/0D50X00009XkhppSAB/cosmic-checksum16-problems
The answer to my problem is there: a software breakpoint. I wasn't familiarized with software breakpoints implementations so I didn't figured out before.
Thanks for the help.
David
