I am using STM8S001J3 MCU for my application. For the development purpose I am using STM8-SO8-DISCO development board. Suddenly I am not able to program the board.
DPate.6
It shows following error message when I program the board. Please find attached image for this. I am using IAR embedded workbench IDE for my development. Please help me with this as I am facing this issue since two days and not able to crack it.
Deepak
3 REPLIES 3
Probably downloaded some code that reconfigures or breaks the SWIM pins/operation
Review the code you last downloaded to determine what you did, and perhaps routes to recover it
DPate.6
I have review the code. I am just using gpio and timer. Also SWIM pin is not used anywhere. It is only used for programming. I tired creating new project but it shows the same error. It has stopped suddenly
prain
Senior III
Try to connect under reset. hold reset line, start programming, then release reset line.​
