How to enable and disable a maskable interrupt from inside an ISR in stm8A
raja1
Hello all.
I have an ISR inside which I want to disable and enable interrupts.
Reference manual says :
https://www.st.com/resource/en/reference_manual/rm0016-stm8s-series-and-stm8af-series-8bit-microcontrollers-stmicroelectronics.pdf
Disabling the interrupts
#asm
PUSH CC
POP ISR_CC(1)
SIM
#endasm
Enabling the interrupts
#asm
PUSH ISR_CC(1)
POP CC
#endasm
I want to achieve mutual exclusion. I have tried using sim and rim and it works for now.
However the above method got me confused.
What do I do for POP ISR_CC ?
Please suggest me exact ways.
I have found this inside a blog. Is it correct?
uint8_t atomic_begin(void) __naked {
__asm
; Copy CC value, put in A reg for return value, and disable all interrupts.
push cc
pop a
sim
ret
__endasm;
void atomic_end(const uint8_t istate) {
(void)istate;
__asm
; Restore CC from arg value in A reg.
push a
pop cc
__endasm;
raja1
I was using cosmic c compiler.
I did the following modifications for cosmic C and stvd.
#asm
push cc
pop a
sim
#endasm;
(void)istate;
#asm
push a
pop cc
#endasm;
//Usage is as follows
ISR()
uint8_t ISR_CC_ret =  atomic_begin();
//execute your ISR
atomic_end(ISR_CC_ret);
raja1
	__asm
		ld a,cc
                push cc
		pop a
		sim
		ret
	__endasm;
	(void)istate;
	__asm
                ld cc,a
		push a
		pop cc
	__endasm;
@raja1 wrote:
Hello all.
#asm
PUSH CC
POP ISR_CC(1)
SIM
#endasm
#asm
PUSH ISR_CC(1)
POP CC
#endasm
__asm
push cc
pop a
sim
ret
__endasm;
(void)istate;
__asm
push a
pop cc
__endasm;
Does this make sense?
raja1
#asm
push cc
pop a
sim
#endasm;
(void)istate;
#asm
push a
pop cc
#endasm;
ISR()
//execute your ISR
