hello sir i use the nucleo stm8s208rb with asembler language, so i start with the st visual develop and write even a small program l
debruyne.marc
hello sir
a very simple asembler program ,with a big problem
its in ST visual develop , with the inside st assembler
that simple program
ldw X,#stack_end
ldw SP,X
 PUSH $C
 SUB SP,#$02
gives that error
 Error 54: Can't match Addressing mode ' SUB SP,#$02'
how can that besolved?
and please no answer as learn c.
many thanks
https://www.st.com/resource/en/release_note/rn0005-st-assemblerlinker-asm-452-lyn-319-obsend-215-stmicroelectronics.pdf
"3.1 ASM limitations 3.1.1 Limitations for STM8 assembler �? The mnemonics of the following STM8 instructions: ADD SP,#byte SUB SP,#byte have been replaced by: ADDW SP,#byte SUBW SP,#byte"
Use SUBW SP,#$9
4 REPLIES 4
Peter BENSCH
Essentially the same question as this one.
/Peter
Perhaps there's some issue with spaces, or that the syntax for SP is always immediate,ie SUB SP, 2
Ok, so won't tell you to do that, but if you want to find a richer set of examples and use cases for instructions and forms that you're unfamiliar or unsure of, having the compiler generate a LISTING file, or having a disassembler or debugger generate a disassembly can be quite useful.
Use SUBW SP,#$9
