COSMIC LKF File
balmukund66
Posted on May 27, 2013 at 11:48
Hi All,
I want to execute some command in .lkf file for COSMIC Compiler condionally.
is it possible??
Pseudo code is as below:
#ifdef TRUE
obj\libisl.sm8
#else
obj\libis0.sm8
#endif
Balmukund Prasad
luca239955_stm1_st
Senior II
Posted on May 28, 2013 at 08:44
no, it is not possible.
Strange question though: what did you want to do with that?
Regards.
balmukund66
Posted on May 28, 2013 at 10:55
Hi Luca,
Thanks for confirmation.
Actually i wanted to change memory model dynamically based on some MACRO.
Thanks & Regards
Balmukund Prasad
luca239955_stm1_st
Senior II
Posted on May 28, 2013 at 16:08
For that I would suggest you use a makefile/batch/script (depending on your OS and your preferences) that, depending on the memory model chosen
- calls the compiler with the proper command line
- use different linker files for every memory model
Regards.
