COSMIC and OPTION_BYTE
tfeuerstein
Posted on March 30, 2011 at 15:48
3 REPLIES 3
brazov22
Posted on May 17, 2011 at 15:12
A solution can be to embedd C source code for option byte programming at the beginning of your project:
/* Define FLASH programming time */
    FLASH_SetProgrammingTime(FLASH_PROGRAMTIME_STANDARD);
 /* Unlock Data memory */
    FLASH_Unlock(FLASH_MEMTYPE_DATA);
/* Program value and complement value at adress and address + 1 */
    FLASH_ProgramByte((add), val);
    val_comp = (u8)(~val);
    FLASH_ProgramByte((add + 1), val_comp);
 brazov2
Hello all !
I'm trying to preinit my MCU's OPTION_BYTE to create a binary with the OPTION_BYTE allready set !
This work fine with a assembly file in Ride7 with raisonnance compiler, but now i'm trying to do the same thing with ST Visual Develop and Cosmic compiler but I don't work !
Of course a find pseudo-solution, but I want a solution without modifying the linker command file (this isn't a profesionnal solution !)
I don't agree with the other solution trough STVP, because my code will be shared I prefer something in a assembly file or C source to avoid mistake instead of a extra manipulation ! And I prefer something who work in debug mode too !
Please help me !
brazov22
typo error: instead of FLASH_ProgramByte use FLASH_ProgramOptionByte
brazov2
Posted: Thursday, March 31, 2011 11:39 AM
Subject: COSMIC and OPTION_BYTE
 brazov2
tfeuerstein
Thanks but I found by myself what i'm looking for !
Here is my code :
#pragma section const {OptionByte}
    const struct OPT_struct OPTION_BYTE = {0x00, 0x00, 0xFF, 0x02, 0xFD, 0x00, 0xFF, 0x00, 0xFF, 0x00, 0xFF, 0x00, 0xFF, 0x00, 0xFF};
#pragma section ()
You need to add this new section in your lkf file, forget hand modification, goto Project -> Settings -> Linker -> Category : Input
Add a Segment and add a sub section, enter address of start and end.
Set the option of the section to -k to avoid linker optimisation, the linker will keep this unused section.
The final binary fille will include the OPTION_BYTE set according to your need !
