STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
How to test FLASH_EraseBlock() in STM8AFxx using STVD
Posted on December 18, 2017 at 15:18I followed the below steps to execute the Sample code provided by ST. - For Cosmic Compiler:  1- Uncommented the ''#define RAM_EXECUTION  (1)'' line in the stm8s.h file,    2- In STVD Select Project\Settings\Linke...
Touch sensing library
Posted on August 31, 2009 at 14:25Touch sensing library
tran by Associate II
  • 1203 Views
  • 3 replies
STM8L Execute from RAM at flash block programming
Posted on December 14, 2017 at 13:10Hello, no block or place matches the pattern 'ro code section FLASH_CODE in stm8l15x_flash.o' error appered after adding  #pragma location = 'FLASH_CODE' before block programming function in IAR complier? Any help...
FlexLM compiler error
Posted on December 07, 2017 at 12:41#error cpstm8 C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8\mods0.h:1 FlexLM No such feature exists.
Any plans for low pin-count STM8L devices?
Posted on October 23, 2017 at 10:53Occasionally we have need for a 6, 8, or 14-pin MCU.  For instance SOT23-6 or leadless devices to conserve board space.  Up until now, PIC10 and ATtiny have been the only choices, but it's good to have some other o...
Modify SPI register
Posted on November 27, 2017 at 12:55Hello Everyone,I am working on the STM8AL3166 and try modify the SPI register. My simple code is as below :int main() {   SPI_CR1 |= 0b00100100;      /* Configure as master and 500 kHz com speed}As read in the dat...
david.ye by Associate II
  • 1304 Views
  • 5 replies
How to overcome overlap error in stm8
Posted on December 05, 2017 at 14:40I created one segment and using #pragma i store some values in that location.If my code size cross that memory area means, overlap error occurs.How can i overcome with this error?
saran raj by Associate III
  • 1152 Views
  • 3 replies
