STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
Resolved! STM8S001J3: Unable to communicate with the device
I am trying to program the STM8S001J3 microcontroller, on a custom board. I am using ST Visual Programmer tool for flashing the program but I’m running into the following error continuously.I have tried using both ST-Link/V2(A) and ST-Link/V2(A) ISOL...
samruddhi_daithankar_0-1720694091131.png samruddhi_daithankar_1-1720694091159.png
Resolved! Documentation/Path for learning STM8S
Hello community,I'm looking for materials to learn STM8S programming.I searched on the internet but I couldn't find anything. Can you recommend me any documents or links to learn, please?Thank you all!
Minh by Associate II
  • 4182 Views
  • 12 replies
  • 13 kudos
Unable to generate a PWM pulse
I am using the ST discovery board, which has STM8S003K3. I have written a code that generates a PWM pulse when ADC senses that the input voltage is higher than a threshold value. I have tested this program with a Potentiometer and verified the wavefo...
COMPILATION PROBLEM - "symbol multiply defined"
Posted on October 31, 2013 at 10:13   I am using STM8S 105C^Discovery with a Windows 8 Laptop. I tried to compile some example codes using Cosmic C Compiler with an Evaluation Key, but I got some errors.  Here is the message I got ===================...
ebotsmith by Associate II
  • 4286 Views
  • 4 replies
  • 2 kudos
Can't get stm8s003f3p6 to work with LCD1602!
Hello there! I am trying to get an stm8s003f3p6 to display text on an LCD1602 the LCD has the adapter board PCF8574 on it.I'm using STVD and cosmic C compiler. I used chatgpt to write the code and after quite a bit of tweaking i got it to compile and...
ram80 by Associate
  • 927 Views
  • 1 replies
  • 1 kudos
Not able to print Floating Values using STM8S103F3P.
I am doing a Current, Voltage Measuring project using INA219 Current Sensor and using STM8S103F3P Mini Development Board. And monitoring the data in Serial Monitor. But I am not able to read/write Floating Values. For Eg: Multimeter is measuring 21.2...
Assembler examples requested
I am new to STVD. I would like to make some assembly level programs. Is there any assembly example programs ? please help
joseateg by Associate
  • 878 Views
Debugging Error with STVD version 4.3.12
I am new to STM 8I have just started assembly level programs on ST visual Develop. Version id 4.3.12.I can not debug my test program.When ever  I start debugging and clicking run  command the IDE hangs. I use windows 7  . Please help
  • 718 Views
  • 0 replies
