Assign register value to variable
artvolk
Posted on June 06, 2011 at 21:05
Good day!
I'm trying to assign register value to a variable in COSMIC C. I've tried the obvious way first, but it doesn't work:
uint8_t test = 0;
test = CLK->SWCR; // define from stm8s.h
and
uint8_t test = 0;
test = CLK_SWCR; // define from ''C:\Program Files\COSMIC\CXSTM8_32K\Hstm8\iostm8s.h''
When I run my program in Debug mode and create a watch for 'test' variable it is always zero.
What can be wrong?
Thanks in advance!
luca239955_stm1_st
Senior II
Posted on June 07, 2011 at 08:31
one possibility is that your variable ''test'' is optimized away: declare it volatile as a minimum.
Also check that the hardware register you are reading does not actually contain zero.
Hope it helps.
Luca
artvolk
Posted on June 07, 2011 at 22:54
Thank you a lot, it seems it was really optimized, despite it was builded in Debug mode.
'volatile' does the trick, thanks a lot!
