How to install STM32CubeProgrammer on Raspbian?
Moritz1
Hi there,
I want to flash a HEX file using a Raspberry PI. So I followed the steps described here.
But if I run this line:
$> ./SetupSTM32CubeProgrammer-2.13.0.linux
I get the message:
bash: ./SetupSTM32CubeProgrammer-2.13.0.linux: cannot execute binary file: Exec format error
Has someone an idea why this is not working?
Im running Raspbian GNU/Linux 11 (bullseye)
Sara BEN HADJ YAHYA
Hello @Moritz​ ,
Thanks for your feedback,
Actually it is not possible to install CubeProgrammer on Raspberry Pi as it is not supported on ARM based devices.
I hope this helps!
Sara.
Moritz1
Hi, in the downloaded zip there is no install.sh
so the line
sudo ./install.sh gives me the error "No such file or directory"
Sara BEN HADJ YAHYA
Hello @Moritz​ ,
I hope this helps!
Sara.
AScha.3
Chief II
