Getting ST-LINK error (DEV_TARGET_NOT_HALTED) while connecting my device with STM32CubeProgrammer
‎2022-01-28 4:36 AM
I am facing an issue while connecting my STM32H745 device with STM32CubeProgrammer.
I tried various suggestions posted here by different users for similar questions. However, still, I am not able to connect my device with CubeProgrammer
Below are different ways I tried already
- Placed Boot pin to High state before power-up. So that STM32 boots from system memory.
- Also, tried to connect the device with CubeProgrammer by setting "Under Reset" mode in the CubeProgrammer
- Tried with lower clock speed 8000 in the CubeProgrammer
Let me know what else I can try to overcome this issue
STM32CubeProgrammer
STM32H7 series
‎2022-01-28 4:58 AM
hello
Forcing BOOT0 high only during the initial power-up did not work.
Forcing NRST low at various points in the programming cycle also did not work. If I held it too long I would get TARGET_HELD_IN_RESET, and any time shorter I would get DEV_TARGET_NOT_HALTED.
‎2022-01-28 5:03 AM
Thanks for the suggestion.
I forgot to add this one to my list. I already tried this suggestion as well but it did not work out.
