The 6-channel ADC is converted to DMA but only the first channel is changed?
LMiss.1
Here is my program, but only the first route has AD change, but I give 3.3V or 0V.I use Cubelde 1.3.0 and CuBlemx6.2.0 software.
  • I don't know why not enter the ADC callback function?
typedef struct tagAdcStatus
  INT8U AdcChFlags;
  uint16_t AdcConvertedValue[12];
}TAG_ADC_STATUS;
TAG_ADC_STATUS TagAdcStatus;
HAL_ADC_Start_DMA(&hadc1, (uint32_t *)TagAdcStatus.AdcConvertedValue, ADC_MAX_CH_LEN)
/* USER CODE END 0 */
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
/* ADC1 init function */
void MX_ADC1_Init(void)
 /* USER CODE BEGIN ADC1_Init 0 */
 /* USER CODE END ADC1_Init 0 */
 ADC_ChannelConfTypeDef sConfig = {0};
 /* USER CODE BEGIN ADC1_Init 1 */
// HAL_ADC_MspInit(&hadc1);
 /* USER CODE END ADC1_Init 1 */
 /** Common config
 hadc1.Instance = ADC1;
 hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
 hadc1.Init.ContinuousConvMode = ENABLE;
 hadc1.Init.DiscontinuousConvMode = DISABLE;
 hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc1.Init.NbrOfConversion = 6;
 if (HAL_ADC_Init(&hadc1) != HAL_OK)
  Error_Handler();
 /** Configure Regular Channel
 sConfig.Channel = ADC_CHANNEL_2;
 sConfig.Rank = ADC_REGULAR_RANK_1;
 sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
 if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
  Error_Handler();
 sConfig.Channel = ADC_CHANNEL_3;
 sConfig.Rank = ADC_REGULAR_RANK_2;
  Error_Handler();
 sConfig.Channel = ADC_CHANNEL_4;
 sConfig.Rank = ADC_REGULAR_RANK_3;
  Error_Handler();
 sConfig.Channel = ADC_CHANNEL_5;
 sConfig.Rank = ADC_REGULAR_RANK_4;
  Error_Handler();
 sConfig.Channel = ADC_CHANNEL_6;
 sConfig.Rank = ADC_REGULAR_RANK_5;
  Error_Handler();
 sConfig.Channel = ADC_CHANNEL_7;
 sConfig.Rank = ADC_REGULAR_RANK_6;
  Error_Handler();
 /* USER CODE BEGIN ADC1_Init 2 */
//校准
 /* USER CODE END ADC1_Init 2 */
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
 if(adcHandle->Instance==ADC1)
 /* USER CODE BEGIN ADC1_MspInit 0 */
 /* USER CODE END ADC1_MspInit 0 */
  /* ADC1 clock enable */
  __HAL_RCC_ADC1_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /**ADC1 GPIO Configuration
  PA2   ------> ADC1_IN2
  PA3   ------> ADC1_IN3
  PA4   ------> ADC1_IN4
  PA5   ------> ADC1_IN5
  PA6   ------> ADC1_IN6
  PA7   ------> ADC1_IN7
  GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5
             |GPIO_PIN_6|GPIO_PIN_7;
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  /* ADC1 DMA Init */
  /* ADC1 Init */
  hdma_adc1.Instance = DMA1_Channel1;
  hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
  hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
  hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
  hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
  hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
  hdma_adc1.Init.Mode = DMA_CIRCULAR;
  hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
  if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
   Error_Handler();
  __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1);
 /* USER CODE BEGIN ADC1_MspInit 1 */
 /* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
 /* USER CODE BEGIN ADC1_MspDeInit 0 */
 /* USER CODE END ADC1_MspDeInit 0 */
  /* Peripheral clock disable */
  __HAL_RCC_ADC1_CLK_DISABLE();
  HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5
             |GPIO_PIN_6|GPIO_PIN_7);
  /* ADC1 DMA DeInit */
  HAL_DMA_DeInit(adcHandle->DMA_Handle);
 /* USER CODE BEGIN ADC1_MspDeInit 1 */
 /* USER CODE END ADC1_MspDeInit 1 */
 * Enable DMA controller clock
void MX_DMA_Init(void)
 __HAL_RCC_DMA1_CLK_ENABLE();
LMiss.1
  • Here is the code automatically generated by the IDE:
 /** Common config
  Error_Handler();
  Error_Handler();
  Error_Handler();
  Error_Handler();
  Error_Handler();
  Error_Handler();
  Error_Handler();
 HAL_ADCEx_Calibration_Start(&hadc1);//校准
LMiss.1
  • Why is there no code for the DMA register?
