STM32f4 Regression in STM32CubeMX SysClock frequency HSE_VALUE setup 4.26.1, STM32Cube FW_F4 V1.21.0
CHABIN.Laurent
In stm32f4xx_hall_rcc_ex.c
is using a HSE_VALUE that does not reflect the settings in STM32CubeMX
it uses the default 25Mhz in stm32f4xx_ll_rcc.h instead of the one in hal_conf
this problem did not occur in a previous stm32cubemx fw release.
the result is off the roof frequencies and potentially unexpected behavior.
pay me a beer.
Imen.D
I will raise this issue internally for check. Please, share your ioc file for check your case.
With Regards,
Imen.
Imen
CHABIN.Laurent
Here is the file.
Houda GHABRI
Hello @Community member​ ,
Thanks for your feedback and sorry for the late answer.
you can switch to last STM32CubeMX version 4.27.0 available on Web .
regards,
Houda
