STM32CubeMX 4.25.0 - Truncation of the clock page in the PDF report
Andrea Canepa
Posted on May 09, 2018 at 10:08
I set CubeMX to configure STM32H743ZI, I made my settings in the peripherals and on the clock page.
The clock page of STM32H7 is very wide as there are several settings so it must be scrolled down to see all the settings.
Then I generated the report (Project -> Generate Report): I opened the report in PDF and I found that the page '4. Clock Tree Configuration' is truncated on the right side of the page.
Because of this bug it is not possible to see the whole clock configuration page, but only the top one. How can it be solved?
Is this bug known by STM?
Andrea.
#pdf-report #stm32cubemx-4.25.0 #report-clock-page
Nawres GHARBI
Posted on May 10, 2018 at 12:03
Hi
Canepa.Andrea
Thanks for rising this issue we will try to fix it ASAP
Posted on May 10, 2018 at 18:57
The same problem in the 4.25.1
Andrea.
Posted on May 11, 2018 at 10:16
The 4.25.1 has been released before fixing this issue
