2021-01-08 3:31 AM
2021-01-26 7:31 AM
2021-01-27 1:55 AM
Hi @JCool.1
Thanks for the detailed file, generally this type of problem is caused by a java version installed which is not supported by CubeMX.
In fact, the minimum JRE version is 1.8_45 (known limitation with 1.8_251), also the version 11 is supported, for the versions 7, 9, 10, 12 and upper, they are not supported.
Can you please share your log file after facing the issue? (you can find .log file is under \Users\..\.stm32cubemx).
Thanks, Khouloud
2021-01-29 8:28 AM
