Rick V.
Is there a simple STM32CubeMX Ethernet Example I could follow to get my feet wet?
  • November 15, 2019
  • 0 replies
  • 513 views
I'm looking for a simple example of using the CubeMX so I can eventually create an Ethernet tester (a device to test lines and communication). I'm having a bit of trouble finding something that I can understand (not too high a level as I'm a novice with MCU and Ethernet lower level stuff......for now).
I'm still having trouble with this. I'm using an STM32F407VG along with an EasyMx PRO v7 development board. MikroElectronica has examples that work but they require a dongle to compile the program (real bad for configuration management). I need to get an ST example that I can follow but cannot seem to find one, even in the STM32F examples.
