I want to use USART(and not USB_OTG_FS) for serial communication on ST's sensortile. I configured USART2 using Stm32cubeMX and generated the code. The code compiles perfectly, still no output is coming on Teraterm. Am I missing some connections?
Jabeen
Imen.D
Hello @Jabeen​ ,
Make sure you have configured Teraterm correctly and selected the right port with the correct settings: baud rate, data bits, parity, and stop bit.
Best Regards,
Imen
Imen
