2020-03-27 3:14 AM
I install jdk13.0.2 and i have generated jre using following command
bin\jlink.exe --module-path jmods --add-modules java.desktop --output jrethen i add C:\Program Files\Java\jdk-13.0.2\bin and C:\Program Files\Java\jdk-13.0.2\\jre\bin to environment variable ,but i connot run CubeMX in java runtime environment.
