How can I prevent stm32cubemx v1.18 from deleting my files from the project Src directory and the EWARM project? [Solved with 4.19]
howard n2wx
Posted on January 11, 2017 at 18:02
In an IAR/EWARM environment, when I use STM32CubeMX 4.18.0 Project/Generate Code function the program seems to correctly generate its own files but deletes user (that is, my files) from both the EWARM project and from the file system.
It appears this was reported for some earlier CubeMX versions too (
https://community.st.com/0D50X00009Xkf15SAB
for ex). Anyone else suffer and fix this issue?
EDIT 170112 confirmed as a regression --- non-cubic sources preserved with 4.16.0. Not sure about 4.17.0.....
Posted on February 02, 2017 at 17:10
I'm not seeing the problem with 4.19; please disregard
Imen.D
Posted on January 12, 2017 at 08:58
Hello
goldstein.howard
Your issueis reportedto CubeMx team for further investigation.
Thank you for highlighting it and Sorry for the inconvenience it may bring.
Imen
Imen
