2019-12-24 1:48 AM
Hi! I changed usb hid.c file not in user code. After I change something in cubemx and regenerate code this file is also changed to its oryginal form.
Is there a way to tell cubemx not to change this specyfic file?
2019-12-28 2:48 AM
according to my knowledge when you regenerate code all files will ramains as first as it is
2019-12-28 2:48 AM
2019-12-28 3:32 AM
Thanks, well I will change it manually then.
2020-01-01 2:44 AM
Best of luck @oeliks
