Detect_SDIO in CubeMx No solution
Javier1
Principal
Im trying to follow this tutorial but inside platform settings of FATFS i get this:
No found solution for BSP api (SDIO detection pin?)
And when i press generate code i get this warning complaining about the very same thing
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
Hello @Javier Muñoz​,
Thanks for your feedback. In order to correctly configure the Platform Settings for FATFS, a pin should be assigned to GPIO_Input.
Hereafter screenshot showing an example, where I configured PA1 on a STM32F407 as a GPIO_Input:
Hope this answers your question. If it is the case, please click on the Select as Best button on my reply . This will help other members of the community find this solution more quickly.
Khouloud.
Khouloud.
thanks @Khouloud OTHMAN​ !
this worked for me
