Configuration Window needs to be scrollable
Varadharajan V
I'm using STM32CubeMX 5.0.1 for creating projects
While configuring GPIO using configuration window the properties windows on the bottom of selected GPIO pin overrides the visibility of other GPIO pins at the bottom on configuration window
It is not scrolling to view, but we need to select different operation to make all GPIO visible
I'm attaching the screen shots of GPIO Config window without Properties and with Properties
It would be better to make gpio config with scrolling to view the bottom GPIO while property window is open
Varadharajan V
Updated version have this facility and now its look ok
Varadharajan V
No on has still answer ?
Varadharajan V
