BUG: CubeMX allow to set priority for DebugMonitor_IRQn but programing manual NOT
‎2023-07-28 12:48 AM
In document programmin manual, PM0253, SHPR1-3 registers allow to set priority for following handlers:
but Debug monitor writes to reserved field PRI_12:
The same ambigious is in Cortex M4 and perhaps in all
STM32F7 Series
STM32L4 series
‎2023-09-13 10:03 AM
Hello @Kamil Duljas ,
The PM0253 is aligned with Arm Cortex-M7 Devices Generic User Guide r1p2 description, but we got confirmation, you can use PRI_12 to set of the priority of debug monitor for Cortex-M7, Cortex-M4, Cortex-M3 and Cortex-M33.
Thank you for your contribution in STCommunity.
Kaouthar
Kaouthar
‎2023-09-13 10:15 AM
12 being Debug Monitor is also inferred here https://www.keil.com/dd/docs/datashts/arm/cortex_m3/r2p0/ddi0337g_cortex_m3_r2p0_trm.pdf
