2021-04-09 07:44 AM
Hello
A new version 1.2.0 of STM32CubeMonitor has been released on www.st.com.
The new version integrates some fixes and updates to address some points raised by users and keep the tool up to date.
The detailed change list is described in the release note, but I would like to list few ones :
To update the tool, you just need to download the new zip from www.st.com/stm32cubemonitor and launch the installer.
The installer will overwrite the old version with the new one. It is advised to export your flows and copy the setting file, so you will have a backup of your data.
Best regards
The STM32CubeMonitor team
2021-05-21 12:09 AM
Thank you for your feedback Markus. I am checking how we can improve this visibility.
2021-05-20 10:43 PM
behind the above given link there is only the v1.1.0 available. Please update the link or the content on the website.
Best Regards
Markus
2021-05-20 11:21 PM
Hello Markus.
The link is ok. I guess you have clicked, and the version proposed in the button "Get software" is the 1.2.0.
The button "Select version" will allow you to see only the previous version, but not the latest one.
If you click on the blue + symbol on the left, you will see the details and the information that it is 1.2.0.
You can also check the version in the file name after download or in the installer. Please, confirm if it is ok.
Best regards
Stephane
2021-05-20 11:48 PM
Dear Stephane,
I can confirm what your wrote. The v1.2.0 is available if someone click directly on 'Get Software'. I made the mistake to click on 'Select version' first because I assumed that will list all versions that are available. If I remember correct that is the case for some other STM32 tools. Anyway, thanks for your fast response.
Best Regards
Markus
2021-05-21 12:09 AM
