STM32CubeMonitor-Power Initial window size
‎2024-01-27 4:29 AM
When I open STM32CubeMonitor-Power (V1.2.1) the initial window is too large and spans both of my screens.
My setup is HP Evny 17 laptop - Windows 11 (home) with 4K screen (3840x2160), secondary monitor full HD (1920x1080).
Fortunately I can still access the window title bar to move the window down to access the maximise / minimise icons.
Minimising winodw to task bar and reopening has same issue. Only if I Maximising does the window fill my 4K screen or secondary screen corrently.. Could be Windows 11 issue!!!, any idea's?
‎2024-02-15 11:23 PM
Thank you for reporting this incident.
Based on the description of your configuration, we believe the issue is related to multi-screen management with different resolutions.
We will try to reproduce your configuration and, if possible, correct the behavior of our application.
‎2024-05-28 2:42 AM
hi,
any news on this?
the "way to big window" issue exists since at least when the v3 pwr came out and i got one of these.
btw: working with the export data files is super slow, the storage location is a mess. i remember seing tickets adressing that.
also working with the co-installed 1.8 jre is not good practice. its ancient and a security issue. latest available 1.8 jre should be at least Java 8 Update 411 (8u411), co installed is 265 from 2022 !
-> looks like no work on the tool since 2022.
fixing the "way to big window" issue should technically be feasible
