STM32CubeMonitor and STM32CubeIDE - .axf ??
sgran.1
For using need .axf file, not found in my project((. How receive it file? May be need more IDE settings?
25 REPLIES 25
sgran.1
can not to select Folder, have MacBook OS ((
The folder field is a free text field, you have to enter manually the path corresponding to the Debug folder of your IDE project.
On macOS, it is not started by "C:\Users\<your-user-id>\...." but rather by "/Users/<your-user-id>/...".
Generally speaking on macOS, the root directory is accessible from "/"
sgran.1
manualy all ok! only my projects in ICloud/Documents and I not found in my Mac this folder ??? - copy-paste project folder to User directory and manualy .......
Thank you!!! Will be check futher )))
sgran.1
check -- copy/paste dont work for folder path ((((((((((((( only manually ((( wery bad software
Thierry
Sorry I don't understand why your copy/paste doesn't work for folder path.
Could you please copy/paste your the folder path here ?
Do you still face issues with copy/paste if your project folder is not on Apple cloud Documents.
For information, on macOS, the cloud "Documents" folder is accessible from the terminal under :
/Users/<userid>/Library/Mobile Documents/com~apple~CloudDocs/Documents/
sgran.1
founded in google how copy folder/file path -- all ok if copy folder/file pass then paste to any file
But if paste to Monitor --- no anything ((( == dont working((
sgran.1
try ones more paste path for Debug folder === nothing, only manualy (((
sgran.1
you can it?
sgran.1
you have Windows os MacOS?
Thierry
STM32CubeMonitor is tested on Linux, Windows and macOS.
After having double check, I do confirm there is a specific bug to copy/paste on macOS.
We will fix this bug in a future release.
Thanks for reporting this issue.
