STM32 NUCLEO-LPM01A: Can we change default settings ?
David R
I am currently using NUCLEO-LPM01A to measure current consumption.
Is it possible to change default settings when starting the board?
For exemple, I would like to change parameter integration time from default value 1 to 100s.
In this case, without computer, manipulation would be easier for technician to see more precise current average than for 1s.
Si this would be to:
Measure current consumption with external board without computer.
David
Philippe Cherbonnel
Hi David,
Unfortunately, it is not possible to change default settings at board power-up.
Best regards
Philippe
Philippe Cherbonnel
Hi David,
Best regards
Philippe
