2020-08-04 2:58 AM
Dear all,
How to adjust the layout of dashboard components as a whole?
I now find that each component can only be individually sized and cannot be placed in a single panel to evaluate the layout as a whole.
My dashboard is a mess.
2020-08-04 6:51 AM
Hello Fhu.1,
In order to modify your layout:
1 you need to click on the burger menu, on top right side,
2 select layout of the group your buttons belongs to
Then you can move the elements the way you want
Hope it helps
Richard
2020-08-04 6:51 AM
Hello Fhu.1,
Hope it helps
Richard
2020-08-09 10:56 PM
Thank you very much for your answer, now my dashboard looks much more comfortable, ha ha!
Thank you!
