Cannot get c/c++ search to work
wfd
Quite simple, I try to search for  a variable and when I click search even though I KNOW it's in the project. The window disappears and nothing is done. Is this a bug or Is my search wrong? I'm trying to search the entire project.
This is quite frustrating. (See Below)  Thank you
3 REPLIES 3
You can do a File Search instead, and/or choose Workspace as scope. C/C++ might not think the code you want to find is active or part of the current project. File Search will find it regardless.
Issamos
Lead II
Hello @wfd
I've tested and it works fine for me.
I suggest you to update your CubeIDE virsionif is not the last version.
Best regards.
II
I just upgraded to the latest version and it still does not give me the search results. Could something else be wrong?
