Why USB CDC fails on open if cache is not enabled?
AIach.1
I have created a project with STM32cubeIDE using usb CDC.
If cache is not enabled, accessing via firmware a specific variable located at ox20005604 (for example reading it) once a time, it causes that subsequent open from PC of the serial port returns an error (code 87).
AIach.1
Sorry..it is not dued to cache, it depends only on ram allocation
It depends also from boot (sometimes starts working)... i need some more tests
AIach.1
I'm using STM32F730V8T6
