Aishwarya
The program pauses and refuses to run after access multiple breakpoints access warning (handle_vCont_t, Thread already stopped)
  • April 12, 2020
  • 1 reply
  • 610 views
I got with the CUBE IDE the following problem, at some random point in the program, the Debugger halts and throws the following error:
It occurs several times a weak and I didn't found a solution to this
1 reply
MPaga.1
Visitor II
March 19, 2021
Hi Aish,
I'm experiencing the very same problem and can't find a cause. Since some time has passed, I'm wondering if you have found a solution or some mitigation. Thank you.
