STM32IDE can't connect to Internet.
‎2021-05-10 4:06 AM
Hello everyone,
I have had a problem with the STM32IDE software for over a week. When I want to create a new project, I am asked to download some files from the internet but the software can't connect to the internet to download them. I am using a Desktop PC which is connected to the internet via a LAN Cable. According to some videos on Youtube, I should enter settings such as PROXY and others, but I don't use these settings. Can you explain what I should do? Thanks in advance.
Some screenshots of the error codes follow.
STM32CubeIDE
‎2021-05-10 5:23 AM
The connection depends on the local conditions, proxy settings are only necessary if you are behind a proxy.
Please try:
- setting to Direct instead Native in Network Connections
- then Apply and
- go back to Firmware Updater and click Check Connection
- don't forget Apply and Close, if the connection works.
Good luck!
/Peter
‎2021-05-10 5:38 AM
Thank for the answer... I just tried it, but it didn't work out.
Is there something else, that i can do???
Dupleix
‎2021-05-10 6:13 AM
Just to be sure, did you complete all of the previous steps?
Which Windows version you are currently using?
What are your internet properties of the machine (VPN, etc)?
‎2021-05-10 6:20 AM
Yes i did.
I'm using Windows 10 Pro. I don't use a VPN... just an Ethernet Connexion... which other propreties do you want to know?
‎2021-05-10 6:24 AM
Internet connections > Connections > LAN settings
‎2021-05-10 6:29 AM
here are the parameters I found:
‎2021-05-10 6:48 AM
Please do not provide any personal information such as your IP address or MAC address as this is a global forum that anyone can access.
I didn't mean network parameters, but internet options.
You can access them in your German Windows using:
- Win-S > Internetoptionen > Verbindungen > LAN-Einstellungen
‎2021-05-10 6:55 AM
Here
‎2021-08-01 11:58 PM
I am facing similar kind of issues in my device sometimes it connects to the internet but automatically disconnects and consistently doing the same thing I need help to solve this issue.
