STM32CubeIDE 1.17.0 released
‎2024-11-27 12:42 AM - edited ‎2024-12-11 8:44 AM
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available.
What is new in 1.17.0:
- Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX:
- Added the support for the STM32N6 series
- Added the support for the STM32U3 series.
- Added the support for the STM32WL3x line
- Added the support for the STM32MP23xx microprocessors
- Added the support for the STM32MP25xx microprocessors in a TFBGA361 16 mm × 16 mm package
- Added the support for new microcontrollers in the STM32C0 series and related Nucleo boards (NUCLEO-C051C8 and NUCLEO-C092RC)
- Added the support for new microcontrollers in the STM32G4 series
- Added the support for new microcontrollers in the STM32WBA series and the related B-WBA5M-WPAN board
- Simplified user authentication interface
- Added support for debug authentication with password for the STM32N6 series.
- Improved support of OpenSTLinux plugin to be version agnostic
- Enabled the installation of both STM32MP1 and STM32MP2 flavors of OpenSTLinux plugins within the same STM32CubeIDE instance.
- Added support for flashing the .bin file during debugging.
Main fixed issues in 1.17.0:
Refer to the STM32 microcontroller wiki at:
wiki.st.com/stm32mcu/wiki/Category:STM32CubeIDE_errata
Known problems and limitations in 1.17.0:
How to get STM32CubeIDE 1.17.0:
- Under this link
- Or update your current installation of STM32CubeIDE using: Help > Check for updates (The in-tool update does not allow updating the drivers and ST-LINK server tool. Full installation is required for this to be done).
- Labels:
STM32CubeIDE
‎2024-12-02 1:36 AM
If you want guarantees of support, you probably need to be looking to paid-for commercial offerings ...
‎2024-12-03 9:57 AM
myST -> Login does not work properly on Linux Mint (ubuntu 22 based). I needed to work on some stm32 code pronto today, have a new machine so naturally I downloaded the latest and installed it. Big mistake. It forced me to login repeatedly then promptly forgot, went to myST -> Login and entered my account, then tried to download packages from Help | Manage Embedded Software without luck. cube finder was unable to download the packages too. Finally, I uninstalled 1.17 then reinstalled 1.12. Fortunately, I had a copy of the installer, since it is gone from st.com
Please get rid of this login ***. I have wasted hours. I will not recommend stm32 for future projects if this *** continues. It's prob too late to change for this project, but fortunately 1.12 still works OK
‎2025-01-20 10:51 AM
@Andrew Neil wrote:If you want guarantees of support, you probably need to be looking to paid-for commercial offerings ...
Who has commercial offerings that work?
‎2025-01-21 12:14 AM - edited ‎2025-01-21 12:35 AM
Keil, IAR, Segger?
PS
Rowley Crossworks
Are Wind River still in the game?
‎2025-02-05 5:46 AM
STM32WB07CC Programming Error on Linux due to Case Sensitivity in Memory Definition File Name
Dear STMicroelectronics,
I am writing to report an error I encountered while trying to program an STM32WB07xx microcontroller using STM32CubeIDE 1.17.0 on a 64-bit Linux system.
Problem:
When attempting to program the device, the following error message is displayed in the log:
Warning: No flash region defined for device id 0x1e
Steps to Reproduce:
- Create a new project for STM32WB07xx in STM32CubeIDE.
- Configure the project and generate the code.
- Attempt to program the microcontroller.
Cause:
The issue is related to the case sensitivity of the Linux file system. STM32CubeIDE (or a tool it uses) is looking for the memory definition file named "0x1e.stldr", but the actual file on the file system is named "0x1E.stldr".
Solution:
Renaming the file "0x1E.stldr" to "0x1e.stldr" resolves the problem.
Suggested Improvement:
I suggest that STMicroelectronics implement a solution in STM32CubeIDE to handle this case sensitivity difference on Linux systems. For example, the IDE could ignore capitalization when searching for files, or offer a configuration option to disable case sensitivity.
Thank you for your attention to this matter. I hope this report is helpful for improving STM32CubeIDE.
Sincerely,
- « Previous
- 1
- 2
- Next »
