EdGi
STM32CubeIDE 1.14.1 still does not run post-build command *Resolved*
  • February 27, 2024
  • 2933 views
The bug which was introduced in 1.14.0 which prevents a post-build step command to run, still exists in 1.14.1 with my project.
I have a Windows batch file which should be run after build, and has worked correctly before version 1.14.0
The result of the build post step is:
..\postprocess.bat
make[1]: *** [makefile:97: post-build] Error -1
make: *** [makefile:65: all] Error 2
"make -j4 all" terminated with exit code 2. Build might be incomplete.
@Semer CHERNI
Resolution in following post.
EdGi
EdGiAuthor
It appears that the post-build command is now intolertant of spaces in project paths.
I was able to resolve the problem in my case by surrounding my batch file name in double-quotation marks as follows:
"..\postprocess.bat" param1 param2
lili
Explorer
June 6, 2025
Thank you so much for your post, it really helped me!
1.17.0
Simon Sq
Thank EdGi.
This also worked for me using STM32CubeIDE v1.15.1
