2023-10-19 10:13 PM - edited 2023-10-19 10:20 PM
Hey All,
we are not able to use the latest STM32CubeIDE 1.13.x IDE as the myST login doesn't appear (just the blue animated loading animation).
In our other Eclipse-based applications we just imported our certificates using the keytool into the Java certificate store. For eclipse this seems to work as downloading stuff from the marketplace works just fine.
But this one seems to be ignored by the properitary login mechanism.
Any ideas how to solve this issue or debugging it further?
Thank you!
2024-05-17 12:00 PM - edited 2024-05-17 12:00 PM
Solved. And if I check save this computer it keeps me logged in after closing STM32CubeMX\STM32CubeIDE. I wonder how long until it prompts for credentials again.
2025-03-05 1:23 AM
Hey all,
I had a similar problem with the myST login window on Ubuntu 22.04, but in my case, the Login button couldn't be activated.
I found a bit of a "lumberjack" solution:
