STM Cube ide interface not seen properly
‎2025-02-11 4:21 AM
Left menu tree is not seen properly "General" tab (selected tab) at dark theme. almost I've tried every setting but I can not reach this area. Please help thanks.
STM32CubeIDE
‎2025-02-11 5:51 AM
Works here. What OS, what theme exactly is selected?
‎2025-02-11 6:11 AM
windows 11. and theme setting is look like this:
if I choice light thema there is no problem:
‎2025-02-11 6:38 AM
Darkest Dark is a third-party theme from the marketplace, yes? Stick the built-in themes. Not a lot ST can do to correct other people's themes. Black text is technically visible. Maybe that's what they intended.
‎2025-02-11 7:05 AM
Are there any solution for full RESET every setting. even if delete .metafile notting change. also uninstall not change anything. are there any way to start as my first install day.
‎2025-02-11 8:59 AM
Usually, this requaries creating from scratch your workspace.
‎2025-02-12 12:51 AM
i have uninstall everything and install again. even if I choice "dark" theme from ST, it looks again not seen properly.
screenshot attached
‎2025-02-12 12:52 AM
I have delete everything and download and install again but problem still there. nothing changed
