Should CubeIDE 1.3.1 projects open in 1.3.0?
‎2020-06-16 1:40 AM
Can someone tell me with absolute certainty whether a workspace and project created with CubeIDE 1.3.1 should (is supposed to) open (and build etc) properly with CubeIDE 1.3.0?
I guess it should if only the last digit changed (if that's typical semantic versioning).
I made a 1.3.1 project and sent it to someone with 1.3.0 who can't update to 1.3.1 because his Kaspersky antivirus software claims the update process is malware...
I can't get back to 1.3.0 currently (updated from 1.2 to 1.3.1).
We're having some trouble getting this going, and I'd like to exclude that this is an issue.
STM32CubeIDE
‎2020-06-16 1:54 AM
Yes absolutely from a workspace , build and debug perpective 1.3.1 and 1.3.0 are same and compliant without any issue.
1.3.1 is a minor update only updating (you can compare both install looking at plugins diff) Device Configuration Tool (aka. STM32CubeMX integration).
This way ony 1.3.1 created .ioc file(s) are not 1.3.0 compliant
‎2020-06-16 2:29 AM
Ah, thanks. The .ioc should not be a problem as long as nothing is tried to be altered when opened in 1.3.0? Everything is configured so far, there should be no need for altering the config.
Btw, should I raise a bug report or something, with regards to the Kasperky issue?
Alas I can't give a detailed message or exact file or process, not sure of how much use a mere "Kaspersky don't like it!" is.
‎2020-06-16 4:44 AM
Let's consider ST is tracking such forum exchanges ...
