Required Tx_SecureLEDToggle_TrustZone example for B-U585I-IOT02A
‎2023-06-01 1:43 AM - edited ‎2023-11-20 4:14 AM
Hello Support Team,
Have a great dat!!!.
I Have B-U585I-IOT02A development kit for our project purpose.
we have created the project as per the below configuring
- Enable trust zone
- Enabled TreadX in non-secure region
- Created API Secure side Toggle LED and called through NSC region
Also, configure chip through cube programmer for secure region bank 1 and bank2
but we are facing hard faults when we call the NSC region api.
Can you supply a similar example for B-U585I-IOT02A based on the screenshot I took of the same example that is available for different series?
Also, provide a step of chip configuration through the cube programmer
Hiren R. Thumar
STM32CubeIDE
STM32U5 series
‎2023-06-02 11:41 AM
As per observation of generated ST code has an issue of allocation of the stack for task created in the non-Secure region.
You can take an attached code reference for your further development.
Thanks,
Chintan Patel
‎2023-06-04 9:17 PM
Hi Chintan
Thanks for the quick response and solved this problem.
