Explorer
January 14, 2025
Regarding Serial communication between STM32 Nucleo F401RE and Labview
  • January 14, 2025
  • 1 reply
  • 1004 views
Dear ST community,
I want to send some data (like an integer or a decimal number) from Labview to the STM32 Nucleo F401RE board for motor speed controlling application.
I have tried using NI DAQ (using digital output pins) and NI VISA. i am finding it difficult to get the output.
what are the steps to be taken ?
Shruthi
Best answer by Andrew Neil
That's a question about NI DAQ and/or NI VISA - neither of which has anything to do with ST or the STM32.
You need to go to NI for help with their tools:
https://www.ni.com/en/support.html
@Shruthi1 wrote:
I want to send some data (like an integer or a decimal number) from Labview to the STM32 Nucleo F401RE board Shruthi
As far as the STM32 is concerned, that's purely about receiving serial data - the NI stuff is irrelevant.
The STM32 neither knows nor cares what generates the data - all it sees is bytes arriving at the UART's RX pin.
You can test your STM32's UART reception just using a simple serial terminal:
https://community.st.com/t5/stm32-mcus/implementing-uart-receive-and-transmit-functions-on-an-stm32/ta-p/694926
https://wiki.st.com/stm32mcu/wiki/Getting_started_with_UART
1 reply
Andrew Neil
Andrew NeilBest answer
